727 starter ring gear needed
AZMoparJoe
6:15 AM
USA
Does anybody know where I can get a replacement starter ring gear for a 10.75” 727 converter? Sonnax shows one, part number CH-RG-130, but can’t seem to find a provider for their parts. I don’t want to junk an expensive converter for a broken starter tooth.
The one in stock at Summit is the CH-RG-130T, which is for a 12.162” inside diameter. I need a ring with an 11.19” inside diameter. The “T” in the part number is the difference.
Why not send the converter in and have it repaired?
I already removed the ring gear from the converter. Only one tooth needs to be repaired. I’ll weld it up and file it. The ring gear isn’t hardened like the starter gear is. Been done many times. Just thought I’d ask if anyone knew of a source for a replacement ring.
What did Coan say about buying one from them?
None of those are correct. Those have a 12.162” inside diameter. I need a ring with an 11.19” inside diameter.
There are 4 ring gears and 2 different sizes, click on the info tab and the ATP ZA505 shows 11.19 inside diameter.
That’s a 122 tooth ring. Mopars A/LA and B/RB use a 130 tooth.
Did you call Coan???? That might me a special ring.
I found a joint in New York that has the correct one. I’ll weld up my existing ring, and pick up a new one as a spare.
Look at the starter bendix, lots of room for different tooth counts. This isn't like a splined shaft.
In over 50 Mopars I’ve built, restored, owned, and raced, I have never had anything but a 130 tooth starter ring. I appreciate your input.
