727 starter ring gear needed
The bellhousings move the starter depending on flywheel size.
The starter engagement is the same
That’s nice. Is there a reason you keep coming back for more? Are you trying to prove a point? As mentioned above; the 727 bellhousing is designed around a 130 tooth starter ring. What else do you have? Or are you going to continue to reply just to reply?
That’s nice. Is there a reason you keep coming back for more? Are you trying to prove a point? As mentioned above; the 727 bellhousing is designed around a 30 tooth starter ring. What else do you have? Or are you going to continue to reply just to reply?
I see your mind is closed on the subject. I won't reply anymore
I’m aware of that. And if a bellhousing is designed around a 30 tooth starter ring, that’s what it gets.
I agree with what you're saying. My post was to clear up the question in post 19 on how it's possible to use the same starter on different size flywheels.
In your situation, is it possible Coan has their own size of converter diam requiring their specific ring gear
Oh I totally agree with that, however the bellhousing has to match the flywheel/converter being used. I have zero clue what that okie rube was going on about.
