Need Help Getting a firm pedal
I have a 1967 Plymouth GTX with a 440 engine and the 727 transmission. I am in the middle of converting to all disc brakes. Everything is installed however I can’t seem to get the pedal to firm up. It wants to go to the floor. I can get it to firm up somewhat by pumping the pedal but as soon as I let go and go to pump it again it goes to the floor.
My system consists of all new parts:
Double Diaphragm Bendix booster
Combination valve PV2
Master cylinder has a 1” bore
(Casting # 2225621)
There is also an adjustable valve installed on the rear brake line after combination valve
The rear brake calipers are of a Cadillac El Dorado (casting #s 184138 184139). These were put on by a reputable shop. They have also been adjusted.
The front calipers are the single piston (2.75”).
New rotors, bearing, hoses etc.
Is there something I’m missing.
I’ve bled the master cylinder and the brake lines more than once.
Have you tested your new master cylinder to rule it out, even though it's new, could be bad. Try blocking off both lines coming from it and your pedal should be hard as a rock. If not, it's a bad one, this has happened to me. If it's good u have air in the system if everything else looks good.
(Casting # 2225621)
That's one of the first things I did. Everything was ok. Guess there's still air somewhere
Took me a long time to get back to this post but I did manage to solve the problem.
The master cylinder was faulty. Returned for a new one and everything is good.
Thanks everyone for your help.
Greatly appreciated.
thanks for the follow-up so we all can learn. It's hard to believe new parts can be bad out of the box, but it does happen. How did you confirm the faulty MC? Also, which MC was the faulty one (brand, model) and which one did you replace it with that now works?
(Casting # 2225621)
I have the same kit in the rear, did you have a hard time with the parking brake adjustments? Also, if you can take some pics of how you setup everything. Can you plug up the M/C and see if that could be bad?
If you have a Wilwood adjustable proportion valve, turn the adjuster all of the way in before bleeding the rear brakes.
How Does a Proportioning Valve Work? And How Do You Adjust It?
The bleeders on the front disc calipers must be at the highest point in order to purge all of the air from the system. Also take care to pump slowly when pumping the pedal. Vigorous pumping can disperse trapped air into thousands of smaller bubbles.
Would a disc/disc proportioning valve be good instead of an adjustable one?
You should not need a proportioning valve with disk/disk...or drum/drum. The proportioning is done by piston size. Proportioning valves only came about
when disks were used with drums because disks need about 50% more pressure, all else being equal.
