Rallye Woodgrain dash panels
steve817
12:58 AM
Casper Wyoming
I’m experimenting with Woodgrain for B body 69-70 Rallye dashes. I know the factory used a paint base process that mimicked Woodgrain on dash panels. Im using vinyl and putting them in extreme environments to see how they handle the cold and scorching hot temps. The vinyl itself is extremely durable. I need to tweak my install process, however, overall, the first piece turned out fantastic! I’m in need of good Woodgrain panel cores. Thoughts? I’m open to constructive criticism. Thanks
Looks like the material my brother used on his 70 rt/se charger
Nice! Looks similar to my 69
Sold a set of cores about 2 months ago. My question for you I believe 69 and 70 were different colors. 70 should be darker. The one you posted looks great. :thumbsup: Biggest problem would be the material adhesive,
Hello Dave, Yes, you ar
Yes, Different woodgrain names, dark walnut, light walnut, Kashmir for E bodies. I’m testing the adhesive now with extreme hot and cold environments and overall durability. Thanks for the feedback! By the way, you are absolutely amazing what you get these Mopars to do on the racetrack. Never would I guess that an old mopar could perform so well. **********************
Thank you, Steve
I bought some originals,wished we talked and I had you do mine. Radio bezel will be the true test.
