Dipstick for 440 with deep pan
Voodoo
12:33 AM
St.Petersburg, FL
Hi all. I am getting close to first start on the 440. Realized I do not have a dipstick yet! My brain is telling me a regular dipstick and tube should work just fine, because it is reading the TOP of the oil level range not the bottom. I believe the engine builder put a Moroso deep sump pan on there (pic below) but that should really only affect the capacity, not the read-range on the dipstick right? I know this is probably a stupid question, but it is more of a sanity check than anything. Thanks in advance.
Full is full yes. But there is 2 schools of thought involved here. First is added capacity so you fill to the full mark using say 6,7,or 8 qts. Second is getting the oil further from the crank to reduce windage. Thus if the pickup is correctly placed you put 5 qts in and remark your dipstick. Take your pick.
If you’re worried about windage put a tray or a scraper in it. It’s just dumb to run a deep pan with less than its rated capacity. Kim
Install the pan, fill the motor with the seven quarts plus the filter, prime the motor and then check the dipstick. Make a mark at the new full point.
I would run it one quart low on the original dipstick. (And that's EXACTLY how I run my deep pans....along with a windage tray).
You will have more oil in it than a stock pan, AND the oil will be farther away from the crank. Win/win.
See engine masters test of oil level.
What 68-500 says just run stock dipstick a quart low.
