BDnFL
Originally power drum all around.
Converted to disc front drum rear by shop. Wilwood front disc with master cylinder. New drums in rear.
Thanks to a member here I see I have an A Body booster with a stand-off from firewall. See pic.
Brakes terrible so I started investigating and found Residual Valve in backwards.
I then pulled master cylinder to check rod length. Rod at least 1/8 long. With it adjusted all the way in.
So here is my questions: Can the A body booster be used?
With master cylinder removed I lightly pressed brake pedal and felt a spring tension on pedal, is this normal ?
Summit does list the A body style with firewall stand-off bracket for B body.
Hopefully it can be used because repiping the master and proportional might be beyond my scope due to access.
