- 4:06 AM
- Oct 25, 2010
- Monroe, New York
But looks to have a very fine clocking index, and once you raise the wrench off the hex, you should be able to remove the wrench, if one used the open slot to place the wrench BEFORE tightening, vs lowering over the stud? Meaning if you got it on, you should be able to get it off, unless I am missing something here.The only issue I see is being forced to have the clocking perfect when tightened in order to remove the wrench from the workpiece.
That's already hard enough with a line wrench.
