FOR SALE 1967 1968 TRW power steering pump
Cop car wagon
12:43 PM
Everett wa
Feedback: +4 / =0 / -0
Before I pulled the mount and tank to clean, I poured atf in and hand turned. It pumped fluid and made a mess.
I cleaned the tank and mount, no rust or dents. I'm sure you would want to do the 2 orings, but front seal should be fine.
Large pulley.
$60 PP f+f. And ship
Shipping quotes for an assembled pump and bracket to the east coast was $48.
Fortunately, the can was off, as it was best to do the orings, so I was able to break it down to all fit in a medium flat rate box.
I have another pump available, for $60.
But to save on shipping, concider the same shipping method.
The height of the return nipple, prevents even a large flat rate box, so its distance and weight.
I'd like to see pics of the second one, as I want it. It has the large return nipple?
Pictures of pump #2.
The can has not been pulled, but bracket was. (And cleaned). Sissor bracket has a rubber bumper that has disintegrated, and will need to find a subsitute.
You can see the dry dirt around the can, so maybe it won't leak after years of sitting.
Back to my previous post about shipping. Assembled, its weight and distance. Apart, med flat rate.
Plus a decent hose for $20. Hose might not fit with med flat rate, apart.
I'd be interested in the hose and an earlier pump with the larger return hose nipple if you can find one.
