capacitor discharge spark plugs
Geff McCarthy
1:52 AM
Portland OR
I have used these on my old Rovers, up to the 90 Sterling which had modern electronic ignition, (Honda-Rover V6 2.7L). There is a noticeable increase in idle rpm and easier strarting. I looked on line and Pulstar popped up. 78 400 in my 63 Fury. Anyone with experience with these?
There's no such thing as magic spark plugs. Except for NGK.
Can you supply a brand name of the plugs or a web site link. Never heard of the brand/type. It really does not matter WHAT generated the spark pulse other than the voltage generated satisfies the ignition system components or engine requirements.....
BOB RENTON
The only thing "magic" about the NGK brand (-5 heat range) is the sheer number of users think they fix all ignition problems......and the amount of $$$ spent searching for the exclusive solution.....Just a casual observation.......
BOB RENTON
After visiting the above website I heard the theme music from the "Twilight Zone"!
Website.
THANK YOU FOR YOUR RESPONSE AND SITE LINK......very interesting concept......somewhat limited application. Would be nice to see a heat range chart and cross references. Even cross to NGK, CHAMPION, AUTOLITE. I could not find a cross listed to plugs for my 2024 Cadillac Escalade with 6.2 liter engine and the equivalent of my 440 six barrel GTX, using CHAMPION J-11Y or UJ-11G or HO-8A, which are 3/8" reach plugs.......@ ~ $ 20.00 each.....a little expensive but ????. Where can they be purchased???.....
BOB RENTON
Wow, the ignorance! I have done a lot of testing on ign systems....& spark plugs DO make a difference. It may be slight, you may not feel it.....or maybe you will feel it.
[1] I tried the Pulstar plugs in my GTO. Idle was definitely smoother. Had them in for about 6m, when one failed. I went back to NGKs as what I wanted to know was proved.
[2] When the Bosch Super 4 plugs came out, I tried them; they had 4 grd electrodes, & the spark was exposed more directly to the mixture. No, you don't get 4 sparks, but the spark 'selects' which grd electrode it will spark to. The plugs should have a long life because of reduced electrode erosion. As soon as I drove the car, I got surging at about 35-40 mph. Only the plugs were changed. Put the NGKs back in, no surging....
Now what? I have paid for these plugs...
So I cut off 2 grd electrodes.....&...could not feel any surging. However, I wondered if there still was surging, but I couldn't feel it. So I went back to the NGKs.
[3] A test by D. Vizard that resulted in a large HP loss...from spark plugs.
Once again, a "cherry picked" article ( without origional engine test conditions ) with unsubstantiated, information by an unknown person......WHO is D. Vizard and what are his qualifications.....where is the total comparison tests attributed and referenced to. Show the entire article, name the publication and date article was published.....or is everything based in Australia and conditions at the time the test was initiated. The average FBBO reader cannot be so gullible as to believe the comment/article in it's entirety......or CAN they be???.....I'm sure, that there are several FBBO members (who shall remain nameless) that would take the information as gospel.....but ...could be attributed to the usual sources ( bad/incorrect coils, ballast resistors, loose/corroded bulkhead connections, ECUs, bad wiring, incorrect A/F ratios, incorrect cooling system components, vacuum leaks, etc.)........just my opinion and observations......comments???
BOB RENTON
Pulstar confirms that they do not make cap discharge plugs for my 400. It is a 78, low comp engine. Suggestions for type of NGK, please!
I wonder what the OP's GTO engine used? Many were 3/8" reach gasketed AC R44S. Perhaps the engine was a transplanted Chevy using a 14 mm tapered seat plugs. You said Pulstar did not make plugs for your B block 400 engine.....3/8" reach plugs....just curious....
BOB RENTON
