Has anyone seen this dual plane Poly intake? Curiosity is getting the best of me. I just found it on E bay. Link below.
Pardon Our Interruption...
That's what I thought too. I questioned that in the title. It looks a lot like the 7503 Weiand.That appears to be a single plane Mike. All runners are at the same level.
I wish they still made the SuperPac manifold. They were cast in Mexico in a small and crude foundry. They supposedly worked well. Designed like an Air Gap.Mike, I just found a thread on A bodies "Tested the new Poly SuperPac manifold" It shows a new dual plane they made and tests it against the Weiand. Good read!
One line of their description says dual plane and the other says single plane. Looks like a Weiand copy.That has my curiosity as well. $500 is a big gamble on an unknown intake. Who is producing these?
Yep.One line of their description says dual plane and the other says single plane. Looks like a Weiand copy.
I have a real nice one but no reason to do a swap if you loose bottom end.A friend of mine is having alum Poly heads & an intake made in China. Not sure if intake is SP or DP design. The Weiand above was pretty poor; on a friends car, there was very little improvement over the stock 2bbl.
One set of heads will be expensive.A friend of mine is having alum Poly heads & an intake made in China. Not sure if intake is SP or DP design. The Weiand above was pretty poor; on a friends car, there was very little improvement over the stock 2bbl.
