- 6:22 AM
- Oct 20, 2019
- Saskatoon Saskatchewan Canada
(Meece??) solution. WORKS!100% agree. I hade a 67 sport fury that got infested over the winter, All windows were up and they actually ate a hole through the vent window rubber. They also hung out on the visors which were up and ate a hole in the headliner. So beware and store your car over the winter with the visors vertical.
Get a bucket.
Punch two holes through the side directly across from each other.
Punch holes in the ends of an empty soda pop can, same size as the rod going across the diameter of the pail.
Start on one side of the pail, install can.
Put the rest of the rod through the other side of the pail.
Slather the pop can with peanut butter.
Put about 4 inches of good old antifreeze in the pail. 50/50 works fine here, but our temperatures get quite cold. You might need less.
Put a board or something else against the pail that the mice can climb, and reach the rod.
They climb up go to the can with peanut butter it rolls over end of problem.
My father was using a metal pail back in the 50’s, if not earlier. Usually used wheat kernels. Mice would die because of lack of water. Sometimes I would take the live mice and feed them to the cats.
FORGOT!! DO NOT PUT THE PAIL anywhere a family pet can get at the antifreeze, it will KILL the pet!!!
