Bergman PS box (Borgeson) and Lares PS box on a 66 Hemi?
What he said.
It's more effort than what I took out. Over powered oe stuff. Additionally, I replaced all of the steering and suspension components, so there is most likely some additional effort just from that. The effort is less than the r&p unit in my 04 Cummins dually, but that doesn't help you most likely. The tech lady was beyond helpful. I asked her about fitment of the unit, especially pertaining to headers. She said if you have stock exhaust, you're fine. Headers, you're on your own. I have Hedman's on the wagon, installed by PO. #3 and #5 had to get thumped. 3 for the box, 5 for the coupler. I also put in a new pump from them which worked out as I had to drop the box in from the top. Took the battery and tray/braces out, pump out, #1 plug out. Pulled the motor mount through bolt on the left side, put a screw jack under the pan rail to tilt it up a little, bingo. From below, no way unless I removed the header. Then I would have had to deal with coolant leaks with the iron head 440. I picked the lesser of the two evils. Along with the box, you need the inlet fitting, which does not come with the box due to differences in years/fitting sizes. If you go on Rock, go to the steering section for your car, hit that and look for "Power Steering End Fitting". Thats the fitting you need for the pressure line. I also installed a filter inline, out of the steering box, followed by a cooler which then heads back to the pump. Also the tech gal told me that Bouchillon has been using the Lares units for some time. Might be an additional info source for you. If you go to Fall Fling, I'll be there with the wagon. You can check it out hands on.
How did you handle the cooler on the high-pressure hose, did you have to use some crimped fittings?
If the Lares unit is a direct bolt in for a fair price, I can see the appeal. I bought the Borgeson because I wanted better feel than any rebuilt original and the weight savings is great. I look to shed weight where I can with the car.
Not with me, personally. I like food.
The cooler usually goes in the return line…
The filter and cooler are on the return side of the box. Ran new hose off the box to the filter, under the battery tray, then to the cooler which is on the horizontal hood latch/grille support[ just behind the grille for best airflow], then hose from it to the pump.
The Lares unit is a direct bolt in. You just need the appropriate inlet fitting for your application. Like they mentioned, if you have headers, you're on your own for fitment. Stock exhaust, no problem. I would like the weight savings too, but it's less costly for me to lose it than the car. But my main deal was bang for the buck. The 65 has a different purpose intended for it. Have a BAC unit for that.
I have the BAC unit for my 65. Haven't used it yet, car is back burnered for awhile. I was going to do the same for the wagon. Kept hearing about the Lares unit here on the forum. Checked the price difference and it was less. Emailed Lares to get some info, then made the buy. I'm watching my expenditures on the wagon, so trying to get the best bang for the buck. Also the 11033 unit has a little faster ratio than the stocker. 11043 faster still. Happy with it so far.
So you have the 11033, correct? What ratio is it?
What ratio is the 11043? Is it the same exterior-wise?
Can't find the ratio, of course, on the 11033. Its 3.5 turns L-L. 11043 does show, on Rock, 10:1 ratio and 2.5 L-L. Same look on the outside for both.
Stock is 3.6 turn L-L.
10:1 ratio is really quick. The T/A's with optional quick ratio are 12.7:1.
And I've heard someone that has restored many T/A-AAR and 100's of Mopar say it was a little too quick for his preference with stock suspension. Even more so with Bias Ply tires.
Just one person opinion. But 10:1 might be pushing it. I'm not sure many OE sports cars even have 10:1.
Google AI:
Porsche's steering ratio varies significantly between models, often featuring a variable, or progressive ratio, which becomes faster (lower ratio number) the more the wheel is turned, for example, changing from 17.15:1 to 13.12:1. Some models incorporate rear-axle steering to adjust the steering ratio and turning circle, while high-performance models may use specialized components like a 911 RS Crown Wheel and Pinion with a 8:35 ratio for a significantly quicker response.
The Borgeson is 14 to 1 with 3 1/2 turns.
A stock Mopar unit was 15.7 to 1 with almost the same amount of turns. That is strange. Add Fast Ratio arms and the ratio changes to the mid 12s with 2 3/4 turns. I find it hard to believe that any aftermarket steering box would be made with a 10 to 1 ratio. That has to be an error.
The 11033 bolted right in. I'd say it's probably more or less about the same weight. Now that I put the box in, I'm pondering if I should have bought the 11043.
The wagon seems more responsive with the new box, but some of that is most likely to being new plus all of the other new items involved in the steering.
11043 is not THAT fast. Yes you can notice it at first, but get used to it after some driving. Many modern family cars have same 2,5 turns lock to lock. I like it.
After doing the install I noticed this space between the pitman arm and the new box. I tightened the nut for the pitman arm with a breaker bar, so it’s tight as hell.
The shaft and the arm are a tapered fit. It will only go on so far. Not going to bottom out unless something is haywire.
Heard from Peter. Sounds like it could be a little problematic with the TRW pump and not enough pressure. Complicating that is the Hemi only has a 5-1/2” crank pulley - I aasume to prevent over speeding the alternator and power steering and water pump at high rpm. He said Hemi pulleys were never available with Saginaw pumps and that might pose a problem at low speed. I guess he normally recommends a Saginaw pump if I understood him correctly and I don’t think it fits an Hemi. And you can’t easily use RB (non-Hemi) pulleys with the Hemi balancer. He knows his Mopars.
So, for this occasional cruiser I’ll probably go with some sort of OEM box and not take a chance. Sounds like there is a bit of favoritism leaning to Firm Feel over Steer and Gear. I’ll probably stick with a level 2 or Modern level to avoid the numb center position transitioning to heavy resistance on either side with the level 3 box that Kern Dog referenced in one of his posts.
Borgeson also has a power steering pump. I think the # is 80338. I put one in my 383 Charger. It says the pressure is 1350 psi. In fact, it was too much pressure for my Lares 11033 box O pit in a few weeks ago. I had to install a pressure reducer. It feels a little better now.
I ended up putting a Steer and Gear level II box and TRW pump on it and I’m so happy with the way it’s working I can’t even notice if it has a dead center or not. It transformed driving the car around town from a real pain to fun and it hasn’t spilled a drop of fluid yet.
hey i got a question got my steering box back from rebuilders do i mount the return valve with the red orings or the black flat ones.this is on my 69 road runner p/s
The more boost that you have, the less you'll feel the slop. The boost makes turning much easier. With a loose steering box, you can saw the wheel back and forth 40 degrees and get no change of direction but with really high boost from the pump, you can't tell where the slop ends and the actual steering response begins. It is like steering on wet ice.
