Tail shaft to Mount Bolts
Voodoo
12:39 AM
St.Petersburg, FL
Anyone happen to know the specs of the two bolts that connect the transmission mount to the tail shaft of an A833 OD? I’ve tried a variety that I have laying around and none have done the trick.
My fallback plan is to buy half a dozen different ones from the hardware store and return the ones I don’t use, but I’d prefer not to do that.
Page 21-19 of the '69 manual. Torque is 40 ft/Lbs and IIRC they are 5/8"-16 bolts.
You are right, 7/16-14. Sitting at home for 5 weeks has made my memory crap!! :thumbsup:
But they're still 40 ft/Lbs...
Now, if you'd said the bolt heads take a 5/8" wrench.... Which I'm fairly sure is what sparked your memory.... :thumbsup:
