advice on front suspension options?
When I installed PST thick torsion bars and thick sway bar + Bilstein shocks, it made a world of a difference
I have a nice "driver" 1964 Plymouth Sport Fury. Stock 383, automatic, 3.23 rear, disc brakes all around, torque thrust wheels. Front end is mostly original and wore out. Looking for options to make even more of a pleasure to drive. I put a Hotchkis in my 69 Coronet and very happy with that, but I do not think they make one for 64 Plymouth. I am not looking for the cheapest thing out there, but also not looking to put $6-8 k into front end. Anybody have any advice for a winter project for me? Thanx, Jack.
I went the QA1 route, and have been very pleased with the quality and fitment of the entire Level 2 front suspension kit. Tubular K member, adjustable strut rods, tubular upper, and lower control arms, bigger torsion bars, and a beefy sway bar, and singular adjustable shocks. I also did away with the stock steering and went with a Borgeson kit.
I don't disagree with much that already has been shared here, except for one aspect. I lean towards best bang for buck of an ungraded OEM TB IFS, 2 way adjustable shocks. big TB's 1"+, SFC or Torque boxes, not both, a real K member (the K member is the Pelvic bone equivalent of the chassis), big brakes, fat hollow sway bar, delrin LCA bushings, lightweight OEM unwelded LCA, etc.
However, if you want the best, highest tech, beefiest, state of the art, purpose designed IFS available today that fits your $8K budget, it's an Art Morrision set up, bar none. I have visited their shop, put my eyeballs on it, and nothing compares.
BTW, I have no dog in this fight. I own what I first suggested above, I also have a Reilly, now modified IFS.
Choose wisely.
Home Page - Art Morrison
Would you be able to weigh what all the new components weigh vs stock ones? Curious what the weight savings is?
1. IMO this is not an area that a lot of weight can be saved without really diminishing the structural integrity of the chassis and the IFS
2. Most previously claimed weight reductions revolved around converting to a lighter disc brake system
3. Any weight saved here is mostly below the COG and has reduced benefits, other than RAISING the COG
4. Weight savings in this area should always be after Alum intake, Alum heads, Battery relocation and FG hood, all items above COG.
5, Most everyone is "pleased" with the mods they have made, as they likely have no empirical data to challenge it, they also have no way to do a real A/B comparison performance wise other than from memory (memory about what???), and the normal human nature effects of confirmation bias, unless something breaks
Go with Quality , Stock Replacements —- they were fine for the first 50 - 60 years of these vehicles….
I can supply you with all 17 items in Top Notch Quality for under $ 1000……
Craig….
I disagree with the lower control arm
Bushings, it was a crappy design when new. Urethane or Derlin bushings and greaseable shafts and add tubular UCAs at the least. The stock stuff was designed for skinny 14” bias ply tires. With modern radial tires you want more caster than the factory can provide.
Explain first why a 1.625" OD? "tubular UCA's are needed at the least" to replace effectively a 3" 10 gauge I beam that has been supplied for nearly 2 decades almost unchanged, is still in use over 6 decades later and has a proven track record in billions? of miles.
Because the tubular arms move the ball joint back to allow for more caster. The extra caster is the single best thing you can do for modern wide radial tires.
Uhhh… I was able to get 6 degrees of caster with stock UCAs (with offset bushings) in two different cars. Tubular ones are not absolutely necessary.
So, your point has nothing to do with "tubular", but moving the BJ back will increase caster?
In regard to caster, in your opinion, how much caster is enough, and can you share any downside to be had with adding additional caster?
Be careful, that last one is maybe a trick question.
I have had the best results with 5 degrees positive on the street, have gone as much as 7 degrees for track days and Autocross.
On my Superbird even with Problem
Solver bushings the most I could get was 3 degrees on the drivers side and 3.5 on the passenger side any more than that and the camber went out the window.
The issues seldom addressed is additional caster adds to steering force/strain on IFS/steering components, which causes weight jacking (by lifting inside turning side of the chassis (forcing that wheel down) and that forces down the opposite outside rear wheel (lowering understeer and increasing oversteer tendencies), and lastly by constantly predisposing the car to always drive straight with no input (take your hand off the wheel), anytime steering the car, you are fighting that tendency of the car, rather than the car doing what the driver intends.
Anybody who drove go karts at a young age learned all about weight jacking with a non-suspension chassis with big caster and a solid axle.
The additional strain is why C body Tie rods are a cheap and timely upgrade, and the additional stability is why I had issue with my Superbird. When I finally got to 5 degrees with welded and re drilled Ball joint sockets in the upper arms the car tracked true at 140-150 MPH, gave more steering “feel” with the Mopar “police” steering box and made a car that was a handful easy to drive with one hand on the wheel well over 100 MPH. As for unloading the rear tire I’ve never experienced that on a vehicle with suspension
The added strain is proportional mainly to steering angle compounded by the weight of the car, not much by the speed. If one is at full lock, you are either parking, or headed to the wall at high speed, and your C body TR are simply window dressing at that point. I assume we are not concerned with hitting curbs here with all our exceptional driving skills.:steering:
You lost me there. A B body has better steering response and corners better with 5-7 degrees positive caster when running modern radial performance tires. I’m sure the sticky 10” wide front tires put more stress on the steering components than the caster setting
Caster puts more strain on steering components, mainly because of weight jacking and the fact the driver has to overcome when turning straight line predisposition.
Wide grippy tires puts mainly more load on the suspension components, unless our concern here is parallel parking.
So, unless we are talking a real wacky set-up with huge scrub, etc, in general we disagree.
Pfft...
Lifting weights puts strain on the man that is lifting them. Running puts strain on the feet and knees.
So what? Why drive a car like a grandma and have no fun with it? We aren't commuting 30,000 miles a year in these cars. If you have to rebuild a suspension in 5 years, again....So what ?
Build the car, enjoy the car and REbuild it later if necessary.
Pfft...
So what?
I have idea.
Best answered by the person who raised the question in the first place and noted the conclusion of why C body TR upgrades are useful?
I only attempted to help clarify what action putting what strain on what item, the strain not being primary concern, but more its result.
