Michael, you bought a vacuum gauge recently, right?
Have you hooked it up yet - that should clearly show if your intake isn't sealing.
Yes i did and it currently only reads 15". From what i've been told 17-18" would be normal.
So you're saying the retired mechanic didn't notice this the FIRST time you installed the manifold...and then blamed the manifold for being warped? So it isn't warped after all?
Is this a new gasket or are you re-using the gasket from last time (you could if it's only got 20 minutes run time on it)? I'm confused as to how many gaskets you have.
Regardless, that gasket looks like it can be shaped to fit the bolt holes
Isn't it upside down on the workbench right now - for you to take all those photos that don't really show anything? Can't you simply put a straightedge on it - or are you waiting for a NOS straightedge to come from the US to be able to check?I still don't know if the old manifold is warped or not. But i hopefully will within a couple days...
