V6 42RH (a500) internal upgrades to V8 42RH (a500) ?
rustytoolss
10:28 PM
New Franklin, Ohio
Were there any internal upgrades between the V6 42RH comparied to the V8 version ? Number of clutches etc. And would they be overly important on a 250hp driver cruiser ? Also do the cooler lines need to be increased from 5/16 to 3/8 ( the only problem I see with that is the internal cooler in the radiator) ?
The biggest I remember since I believe the 42RH is another name for the A500 transmission. All my Dakota Convertibles I've owned have had these. The biggest thing I can tell you is use some of the upgrades from a later 42RH. This will give you a few ideas here in this thread:
The biggest failure point and what I always asked about the Dakota Convertibles is does the (4th gear) overdrive work. The first part on those trucks to own was the overdrive. I think two of them had the transmission rebuilt at lower mileage. If I remember correctly the earlier A500 (42RH) had an problem with keeping the overdrive gear properly lubricated if I remember correctly. I would add a shift kit too. On the other questions, I'm not quite there about the increase in cooler line size but, a safe bet would be to run a decent external cooler.
Also, more information for you here:
