Winter Storage Prep For Rotors
penstar pete
11:20 PM
New Jersey
I'm looking for a good product to spray on my brake rotors for winter storage. My car will be in doors, but last year I had surface rust on the rotors. There are lots of different rust inhibitors out there,
what is everyone using to protect their rotors from rusting over the off season ?
Nothing. Just don't get the rotors wet if you wash it. If you do, drive it and do some braking to heat them up to get rid of the moisture.
What will stop rust and not contaminate the brake pads? Or remove the caliper and coat the rotors, then clean it off and put calipers back on in spring.
I still can't believe how humid the NE USA is. Dehumidifier in the garage in the summer!
You should go to Carlisle in July.
It's a tropical rainforest
I've been there, unreal the moisture. Lots of good cars and parts, but I've never seen so many rusted junk parts as there.
I just park the car and disconnect the battery. In the spring I’ll reconnect the battery and away I go.
I bet a wipe with Ospho on a sponge would work nicely........it would leave a film of iron phosphate that the pads would easily wear off
