Carb Rebuild Kits
VANDAN
10:03 PM
Western NY
I recently picked this up for my hemi build. I'm looking for the Carter carb kits to freshen them up. I also have a Weber carb on my Challenger that needs a going through. Who, and Where does anyone recommend finding these kits ? Any recommendations appreciated, Thanks...
I generally use Standard brand kits and unless pressed for time, I purchase them from Rock Auto.
I got my last kit from Mike's and was very happy with the quality and detailed instructions. Mike's Carburetor Parts
Mikes has good parts and knowledgeable helpful people on the phone. Spend some time on there Web page, tons of good info, but you have to seek it out a bit.
If you buy leather accelerator pump plungers for carters they need to be oiled before installation. A little bit wiped all around it, don't soak it. Then run a dull screwdriver around the insode perimeter on the lip on the leather to make sure it's free. Then the work great.
If you have a check valve for gas to go into accelerator pump well Mikes carb sells them. The check valve are in 66/67 hemi carbs don't think they come in rebuild kits.
I also used Mikes to source rebuild kits and I also purchased tuning kits jets and rods.
Really good well labelled parts and very prompt shipping.
You can use the carb numbers to get the correct parts on the website.
Original Carter kits come up on Ebay every once in a while. You just need to know what number you need. What are your carb numbers.
Another vote for Mike’s rebuild kits. I used them on my Hemi carbs.
#'s are 4139S C6 & 4140S C6. Seller said they are original hemi carbs...
When you order kits order check valves. See explanation. I think the check valves don't come in Mikes kits because they are in 66/67 Hemi carbs. So they don't put them in carb kits my opinion. Never hurts to ask whether they come kits, I didn't get any in kit and paid extra shipping with second order,
oh well didn't break the bank.
They are ordered separately - $12 I think.
I believe those are original Hemi carbs.
They will not have curb idle speed screws that hold the butterflies open - they use the middle 9/16" third idle adjustment in conjunction with the mixture screws.
11/16" accelerator pump diameter.
No, they aren’t included in the kits from Mikes.
Vandan, take good care of those carbs. They are rare/valuable and being matching dates probably even rarer and more valuable.
That's what he said. They weren't cheap, but local & reliable source...
