Do I need 90 degree oil filter adapter for headers?
davek
10:46 AM
columbia SC
70 la 318 with Hooker Comp headers. I was told I do not but wanted to ask you guys. Engine is being assembled now. thanks.
I had Hooker Super-Comps on my 360....it was tight..... so a 90-degree adaptor would be useful.
With Hooker Super-Competition headers...............
And after swapping out with Hugger Style headers by Patriot.......
****Please note that the filter and oil have been changed since this photo was taken. :lol:
I also had to use a short filter due to headers.
If you don't object to a smaller filter Look up Wix 51516
That is for a 2007 Chrysler PT Cruiser Turbo charged. Been using that ( or other brands) on all my Mopars for the last 20 years.
We all change oil way more often on our classics than daily drivers. Just a thought.
I used the trans-dapt filter relocation kit and mounted the filter to my fender. I just made sure to keep the hoses as far from the headers as possible. No issues after 2+ years.
This is FBBO...For Big Blocks Only :poke:
Check with FABO for 318 expertise.:D
:lol:
Seriously though, use a 90 degree adapter to get more distance between the filter and exhaust headers. Heat!
What cam is your engine builder going to use?
See the FABO thread below for 318 cams:
Cams for 318's
I use a Napa Gold 1085 filter with TTI headers and no adaptor. The 1085 is a bit shorter. I think the WIX number is 51085. This is on a 340 but it should be the same on a 318 I believe.
Use the adapter. Done quite a number of header installs back in the day, SB Mopar was always adapter.
