koosh
How do I diagnose that?That sounds like a worn out cone style suregrip, to me.
I know nothing about rear end units
I sure wouldn’t know…. but i guess i have to know first what i have for rear end…need to search how that is determinedCould a too-tight axle play adjuster on the rt (pass side) cause something like this? I wouldn’t think so but something weird going on.
Probably a Sure-grip, not a "posi"....Just found out from previous conversations with original owner:
“8 3/4 with 3.23 gears and cone style posi”
Why? There’s a difference?Probably a Sure-grip, not a "posi"....
Because no Mopar ever came with a Posi. But GM stuff did.Why? There’s a difference?
He specifically said cone style…. I have no clue about either one
He's arguing over a name. Mopar guys want their posi's called sure grips cause that's what mopar called emWhy? There’s a difference?
understood…. When i get this thing on the road, is there something i should listen to or feel if this cone style SURE GRIP had an issue?He's arguing over a name. Mopar guys want their posi's called sure grips cause that's what mopar called em
"Posi" is technically a Chevrolet term (the other GM divisions had their own names for limited slips too). In my opinion, posi has become generic, like coke for a cola, bandaid for an adhesive bandage, and Jello for gelatin. Even some Ford guys use posi, tho it's even more wrong for them.
There are reasons for referring to a sure grip accurately. The earlier ones use clutches, and are more robust than the later cone style, hence more valuable.
Cone styles wear out, but they can be renewed, actually, even tho most say they can't. A little machine work, a washer, and they will work again.
LOL…. Im past those days. A cruiser only for me.Well, usually they don't make noises. They just quit working. (The cone bottoms out on the case. )
If you do a burnout, and it's a right tire one wheel peel, your cone is toast, and will only get worse if you abuse it Too much abuse, and nobody will be able to salvage it.
A worn out cone can be used, just dont kill it with one wheel burnies.
