66 Sat
About 4 months ago I spent many hours porting the intake manifold on my poly engine and opening up the 4 hole plenum into one open space with a cut down divider Porting a Factory 4 Barrel Poly Intake Manifold
The poly intake requires a carb adapter to take the standard Holley or Edelbrock spacing and I had a 1/2" alloy spacer, also with 4 holes. I cut that out to make a twin opening and have been running it like that since June. To be honest all that porting seemed a bit of waste, the car felt pretty much the same and was only 1mph faster in the quarter.
I watched an Engine Masters episode and they reckoned a 1" open spacer was the go for a dual plane manifold so I started searching. In the end I could only find a 3/4" adapter spacer, reversible for square and spread bore from Mr Gasket, so I bought that.
Well fitting it was a ball-ache as the side I needed to use didn't have the right configuration of bolt head for carb, Allen key stud for manifold. I ended up having to drill it out and epoxy the bolts in but it worked.
I just went for a drive and just that minor change, from 1/2" divided spacer to 3/4" open spacer has made an incredible difference. The throttle response is razor sharp now and the car just wants to run. Interesting how these small changes can have a big impact.
