Circuit Protection and the "Shunt wire" by-pass
SOME “good information”, bulkhead by-pass maybe. The problem with the MAD article that everyone likes to promote as proof that all Chrysler ammeters will spontaneously combust, most readers miss the part about the article stating it specifically addresses the late-seventies truck plastic framed ammeter/dash frame melting fiasco. Conflating this issue with every other passenger car, and earlier truck ammeter Chrysler ever used. Totally different issues altogether.
My '68 Dart had a combusting ammeter as did my '80 Power Wagon. My '67 Dart, '68 Coronet, and '73 Power Wagon have not had that issue. I believe the two that did have an issue were daily driven for most of their lives (well into the 90's and beyond) whereas the others predominantly sat the majority of the last several decades.
I'm not on a witch hunt to expel all ammeters, I'm also not going out of my way to save them once they start having problems. And I drive my junk. The '73 and '80 Power Wagons are daily driveable and the '68 coronet will be when it's done. The Darts have been sold but my repair done the E-Berg way worked flawlessly on the '68.
OH NO!!!… ANOTHER ONE!!!
Well… try this. Start up the engine, disconect the battery and make an intentional short. Let us know how much time the engine will keep running.
( just to let you know, I made it, althought accidentally shorting out at alt stud)
EXPERTLY DEMONSTRATED AND EXPLAINED.....complete with thermal readings.....and to those that still do not understand the ramifications of said "shunt by pass wire"....play the video again and listen to the gentleman......his demonstrations and explanations should teach the "self proclaimed experts" how things work and the consequences. I personally commend the author....he should copyright his presentation......THANK YOU for your outstanding effort.......best regards...... BOB RENTON
Load testing this "Shunt wire" underhood by-pass, Safer?
Some more load testing for this "Shunt wire" by-pass. 120+ amps on the stock wiring before any circuit protection opens?
Ok, following very closely, and I'm still confused. I want to prevent any electrical failures on my 70 Roadrunner, which Ive owned since 1996. I still dont see a method to accomplish this. For reference, this car is a Superstorm Sandy survivor, and has had the dash cluster, harness, column electricals, and alternator replaced with new aftermarket. So, the firewall connections are not toast,.... I added a Holley EFI and electronic distributor, and no other electrical additions. I may add the headlight relay mod soon. All this considered, what is the best way to insure my electrical system is properly protected?
All stock configuration? Make sure those added loads (EFI, head light relay, and related equipment) are all connected to the alternator side of the ammeter, NOT directly connected to the battery. May want to consider the C-body recall approach to relieve some current stress off the bulkhead and retain the original function of the stock charging system. Be sure to check out the other videos on the channel where the title video here is located.
Agree with the above. As long as there no "significant" additional power draw on the passenger side of the firewall you'll be fine. That means NO stereo, fuel pump, efi, etc.. HOWEVER, as the engine compartment won't be stock once you add efi, you could add a circuit breaker in the alternator output line before it goes through the firewall. Fusible links are fine but may not blow fast enough to avoid melting the bulkhead connectors! Just a thought!
One of the biggest issues is when using an alternator that can put out over 40 Amps. I don't have a 1970 factory Service manual, but on my 1969 Coronet, the alternator output wire, and the large wiring to the ammeter is only 12 AWG wires size. The Factory fusible link is on the battery side of the wiring which protects the dash wiring from a short from the battery supply side, but if the engine is running, the alternator can still provide current to the dash. When the alternators output is limited to around 40 Amps or less the 12 AWG wire is at it's limit but should handle it for awhile, but the bulkhead connector won't like that much current. A high output alternator puts out too much current for the stock 12 AWG wiring size.
You can add a larger alternator output wire to the battery and add a fuse or fusible link to protect the new alternator output wire. When you do this, DO NOT use the factory alternator output wire as it will create a parallel circuit bypassing the original fusible link.
This creates an issue where all the dash power is coming in on the battery side of the ammeter, so it will always show a discharge.
An easy fix, is to use the old unused alternator output bulkhead connector in parallel with the battery in bulkhead connector with both protected by the single battery side fusible link.
This brings fused battery power into the dash on both sides of the ammeter, so the ammeter won't function, it should just stay centered.
Because all the dash power has to come through the single fusible link you have much improved circuit protection, but are more likely to blow the fusible link with heavy loads being powered through the dash. Powering the headlights through relays is one way to reduce the load through the dash and fusible link.
Another is to power the ignition through a relay. This also helps to reduce voltage loss through the ignition key and bulkhead connector for better alternator voltage regulation when using an external voltage regulator. The rest of the normal dash circuits don't pull much power except the heater blower motor. If you have power windows or convertible top then you might want to re-rout those through fused relays powered from the battery and just triggered through the dash/body sort of like the headlight relay
On my 1969 Coronet 500 wiring harness, I didn't want to cut the original harnesses, so I just removed the necessary engine side terminal connectors from the bulkhead, and the new wires to trigger the relays have the mal Packard connectors that just plug into the bulkhead connector. The relay outputs have the female Packard connectors and using the two connection connector shells, the original wires with their connectors into the other side of the connector shell so no wire cutting, and easy to put back to original.
The electrical system is a "demand" system, in other words current only goes where its needed. That said, if everything on the passenger side of the bukhead only draws a total of 30 amps it doesn't matter if the alternator is cranking out 100 amps in the engine compartment - the only flow through the bulkhead will be 30 amps.
To illustrate this, when you hit the starter the battery is feeding a couple hundred amps - but its only going to the starter, not through the bulkhead. In fact, that couple hundred amps is always sitting in the battery - but only flows out when its needed.
Bottom line: the bulkhead wiring is adequate as long as the total current draw on the interior side is withing the limitations of that wiring.
Now if those original bulkhead terminals (Packards) were rated to handle anywhere near 30 amps of current, we likely wouldn’t be having this discussion. Load up some options, power windows, power seats, power door locks, A/C, C-body? Hence the factory C-body recall approach to parallel around the alternator feed BH Packard terminals. Connect some high current aftermarket loads to the battery/starter relay and you end up with even more current stress on the both charge path Packards at the BH and the ammeter & related wiring/connections.
Yes. I was trying to describe the original protection design for when there is a short or excessive load on the interior wiring, and that the original 12 AWG wiring was not designed for a high output alternator, or several extra interior loads.
With all the wiring questions, and thinking of the changes that are often done like high output alternator, cooling fand, electric fuel pumps and EFI, I have been looking at ways to modify the stock wiring that are simple and don't require drilling or modifying the bulkhead or firewall.
Too bad Bob RJRenton passed, he would be all over this :praying:
