426 Hemi
No Vin car is long gone, can’t see the stamp on block I’ll see if seller can clean tag on block for better pics
66-67 had no vin stamp. Cast date should be on the opposite side of the block from the casting number. If it's got a vin number, it will be on the pad on passenger side lower edge of the block. The pad on the top of the block to the drivers side of where the intake sits will have additional information, as in year and build date, etc.
Here are the numbers found on the block, can someone decode this so I l know what car it came out of, Thanks
No only numbers were what I uploaded
Its for sure a 69 production block by the big E stamped under the bottom, and the 10,000 day calendar date. some early 69 blocks had the complete vin stamped on the machined pad found on the passenger side of the block above the oil pan, while others had the last 8 digits of the vin stamped. It should have that unless its been removed or modified. Please look in that area, and let us know back.
Matt
