Tips on removing passenger side exhaust manifold?
Schultz64
6:58 PM
link lakes, mn
I have a 64 Dodge 440 with a 440 that I am trying to remove the passenger side exhaust manifold. The studs in all bolt holes are about an inch longer than the new ones I bought in case I may need them. The drivers side came off with no issues. The picture shows the clearance. Passenger side manifold comes about half way off the studs then can go no further because of the shock tower. The manifolds are the later factory HP ones.
Is there a way to get the manifold off without lifting up the motor? If I need to lift/jack up the motor what is a good spot for the jack?
Lift the motor. I would just place a thick board under the pan and lift or use a cherry picker and lift.
Thank you pnora. I didn't think the manifolds would be an issue but forgot about the engine offset. The longer than normal studs don't help. Hopefully the lifting goes without issues and I can get to putting things back together.
Undo the passenger side motor mount, and Jack that side of the engine, using a 2x4 on your jack saddle. Don't get too boisterous, so you don't dent/crush the oil pan.
Success. Manifold is off with no paint harmed. Short 2 by6 on the pan rail. While I was under there loosening the motor mounts I saw the fuel line is wet. So I will replace that. Also changed the spark plugs. Thanks everyone for the tip
Did you. Have to remove my h e m m m m minute mount bolt in the passenger side? Having the same challenge on my 82 charger with a 1969 440 RB block.
I removed the 2 nuts on the bottom of the passenger side rubber mount. The top nut on the driver side and loosened the transmission mount. That gave enough clearance. The motor wouldnt drop back down after bolting on the new manifold. I had to put the block on the drivers side oil pan rail and lift slightly and the passenger side dropped back.
I tried jacking it up on the oil pan rail without any bolt removal and it worked! Thanks so much. Been fighting this for half the day
