Gear oil leaking from front of A833
AR67GTX
1:17 AM
Arkansas
I’m getting ready to pull the 4 speed in my 66 to see what it needs. I’ve always had some oil of some kind at the lower front of the transmission and never 100% sure if from the rear main or the transmission. Well, today I cracked the bolts loose to the bellhousing before having to quit for the day. Probably an ounce or slightly more gear oil ran out between the two as they very slightly separated. It’s very distinctly the gear oil I changed into it several years ago - nice thick, clean stuff.
So what leaks mostly at the front of an A833? I know Muncies more than anything and with wear they almost always leak at the countershaft bore in the front of the case. I assumed A833s with an iron case didn’t suffer from this? Is there some common screw up at the front bearing retainer that can cause a leak. My old “how to” book doesn’t describe anything special other than the bearing retainer, seal and gasket but doesn’t provide my detail. Hopefully I will get it out tomorrow - I keep forgetting things in the way like dropping the H-pipe so the transmission crossmember can come out.
I’ve managed to rebuild a Muncie, a Toploader, an 8-3/4 rear end and an A727 successfully in the past and have a press, bearing splitters/pullers and stuff typically needed. Any thing unusual about an A833 in the way of tools or equipment that I may need for rebuilding it in my garage (other than an ape to lug the heavy thing around)?
....and don't forget to either drain the gear oil or plug the hole where the driveshaft yoke goes in. Depending on how much you tilt it you could end up with a large gear oil leak :lol:
And to add further, if the transmission functions just fine and doesn't make any noise I wouldn't do anything further other than stopping the leak. No sense in rebuilding something that doesn't need rebuilt lol.
My a833 book says to clean the countershaft bore seam and dab a small layer of clear rtv to help seal it.
That is my intention as mechanically it’s functioning fine. But I would like to replace the tail housing gasket, fix whatever is going on up front, and install shift fork seals. Right now I’m hoping that doesn’t get into pulling it all apart. I’m hoping I can just unbolt the tail housing and separate it slightly to get the old gasket out and slide a new one in place, probably having to cut it at the top and using RTV to seal the cut. I may not be able to replace the reverse shaft seal if they install from the inside - need to research that. Also want to check out the clutch as I have no idea what’s in it other than it’s a diaphragm type.
Yes - I had a spare yoke I slid in the rear. Wasn’t quite ready for the lube that ran out the front though when I loosened up the bolts a little.
OK - that’s what we used to do as a cheap fix on Muncies, clean the counterbore area fill the slight recess with RTV and slide it into the bell housing and cinch it up.
