- 12:43 PM
- Aug 18, 2024
- Virginia Chesapeake Bay
I’m trying to buy brake parts but my car is not here to measure. 74RR rear drum size. Stock. 10” or 11”?
What they weren’t a standard size?Ask Carnac the magnificent
11" rear drum brakes work with stock 1974 14" wheels.So, if they turn out to be 10” can I convert to 11” and still retain stock 14” rims? What do I need to replace? Drums backing plates and all the internal stuff? I can find drums but not backing plates yet.
| Part | 10” x 2.5” vs 11” x 2.5” |
| Drum | Different |
| Support (backing plate) | Different |
| Shoes | Different |
| Return springs, upper | Different |
| Plate (upper washer) | Different |
| Shoe retaining springs | Same |
| Shoe retaining pin | Different |
| Shoe spring retainers | Same |
| Adjuster/return spring, lower | Different |
| Adjuster | Same |
| Self adjuster cable | Different |
| Self adjuster cable guide | Same |
| Self adjuster cable lever | Same |
| Self adjuster cable lever pin | Same |
| Wheel cylinder | Same |
| Wheel cylinder rods | Same |
| Wheel cylinder bolts | Same |
| Wheel cylinder support seal | Same |
| Park brake strut | Different |
| Strut anti rattle spring | Same |
| Park brake lever | Different |
| Park brake lever lock | Same |
| Lever lock spring washer | Same |
| Park brake cable | Same |
