- 7:40 PM
- Aug 18, 2024
- Virginia Chesapeake Bay
I’m trying to buy brake parts but my car is not here to measure. 74RR rear drum size. Stock. 10” or 11”?
What they weren’t a standard size?Ask Carnac the magnificent
11" rear drum brakes work with stock 1974 14" wheels.So, if they turn out to be 10” can I convert to 11” and still retain stock 14” rims? What do I need to replace? Drums backing plates and all the internal stuff? I can find drums but not backing plates yet.
| Part | 10” x 2.5” vs 11” x 2.5” |
| Drum | Different |
| Support (backing plate) | Different |
| Shoes | Different |
| Return springs, upper | Different |
| Plate (upper washer) | Different |
| Shoe retaining springs | Same |
| Shoe retaining pin | Different |
| Shoe spring retainers | Same |
| Adjuster/return spring, lower | Different |
| Adjuster | Same |
| Self adjuster cable | Different |
| Self adjuster cable guide | Same |
| Self adjuster cable lever | Same |
| Self adjuster cable lever pin | Same |
| Wheel cylinder | Same |
| Wheel cylinder rods | Same |
| Wheel cylinder bolts | Same |
| Wheel cylinder support seal | Same |
| Park brake strut | Different |
| Strut anti rattle spring | Same |
| Park brake lever | Different |
| Park brake lever lock | Same |
| Lever lock spring washer | Same |
| Park brake cable | Same |
DiscWhat do you have for front brakes? Disc or drum?
No. The car is completely stripped down under restoration. This is for when it goes back together. Everything is being rebuilt. I was getting brake parts for the rear today and that’s what started this conversation. If I end up having 10” in the rear I will look at upgrading to 11”. If the rear is 11” I will just buy all the parts. Wilwoods are replacing the front factory discs. New PTFE coated stainless steel hoses, stainless steel lines, ceramic brake shoes, and a Leeds polished master cylinder and vacuum booster.And, are you having brake issues? Having a hard time stopping?
Disc brakes provide 80-90% of the braking force in a combination system. You don't need bigger rear brakes.Disc
I realize this, but I’m buying new everything including drums and the difference in cost for parts is negligible so why not just go to 11’s. The only thing I wouldn’t be buying if I kept the 10” (assuming that’s what I have) is the backing plates. Which right now it looks like the backing plates would be the deal breaker from going to 11’s because it seems they are hard to come by.Disc brakes provide 80-90% of the braking force in a combination system. You don't need bigger rear brakes.
Now this changes everything.And the 11" will reduce handling performance through unsprung weight as well as acceleration due to excessive rotating mass.
