Sheet Metal Divider, How to?
Well, that took a lot longer than it should have, time to start laying out on metal. The worst part, the roll cage is installed and I had to crawl under the cross bar to get into the back seat area, serious PITA!
I always found it easier to go over the crossbar..... but watch your head on the rear bars!.
(And it was over twenty years ago!)
Thought about that, but with my 64 yr old luck I'd slip and rack my berries on the bar! :eek:
OK, cutting metal and wondering how you guys navigated this issue. The place where the roll cage bar passes through the divider, the spot that I didn't cut yet. Did you make a cut along a (see dotted) line to allow the piece to be opened up and pass over the bar? If so, how did you treat the cut line after the panel was in place? Or, is there another way that I'm not seeing? The dotted line in the pic would be from the P/S wheel well to the bar.
None of my bars go through the rear divider or seat back area.
Be sure to consider once you get the metal cut, will it fit through the rollbar to the seat area.
I have to address this myself. I have sheetmetal sandwiched between the seat (still installed) and cross supports, but it’s not sealed, and the package tray is wide open. This racecar thing sure is a lot of work.
