Were they packed with grease or dry? The bearing would have to completely seize for that to happen and/or the axle would have to be too small for a press fit. Usually the factory tapered bearings will self destruct at 60-70k miles if they are not regreased .The inner race on my tapered roller bearing spun on the axle. Got so hot it changed the metallurgy of the race, and reduced the OD of the axle shaft.
No symptoms of anything, not out of adjustment. Discovered when I pulled both axles to check everything out before a long trip.
Never saw anything like it.
Stuff happens.
Greased, not dry.Were they packed with grease or dry?
