Two whole filter reverse manual valve body
Loulang
5:33 PM
Michigan
I purchased a transmission from a guy with a 67 charger because he went with a new hemi and transmission. I checked the numbers on the side of the train by the pan and it is a 67 727 big block transmission. I took the trans pan off and noticed valve body said cheetah 17154. I bought a deeper pan and filter extension and was tearing it down today to start the rebuild process and noticed the valve body and trans filter has two holes in it a filter extension for a 67 only comes with one hole in it. I did some research and one hole is for the rear pump I believe but seeing how this is not a push button trans can I still just use the one hole filter extension? Any help is very much appreciated. Thank you in advance.
You might want to call turbo action. Its a manual shift reverse pattern. Depends on your needs but it may not be desirable on a street car.
Is that number etched into the separator plate or into one of the covers that screws onto the side of the valve body?
The list says it's for a 64/65. So that would be a cable shift valve body and your 68 trans os not cable shift. Sounds like someone has been swapping parts around.
I contacted Turbo action and spoke to the owner and he surprised that I even have it. He said he only made about 10 of those back then. It is for a push button trans. The guy I bought it off of said the trans worked and shifted fine and the only reason why he was getting rid of it is because he went with a new gen hemi swap. He is not a car guy. He has other people do the work on his vehicle. But like I said, he said it drove fine. He just always had to manually shift it. I’m just wondering if that second hole can be blocked off with the single hole filter extension.
I like to smoke the tires leaving car shows I take it to the drag strip every now and then. She’s not just a cruiser. Pic is just some of the marks before I had to put her up for the winter
