Doubtful. A flipper isn't going to look at the finer details.They came up shy on another $225?
That’s not a reflectionLooks like maybe a reflection of the sun off the grass?View attachment 1957960
Oops. We forgot to put the weatherstripping back on.Yep. Why were they left off?
The lighting is strange, but the same yellow shows up on the sill plates.That’s not a reflection
I’m wondering if it’s painters tape that they forgot to remove?The lighting is strange, but the same yellow shows up on the sill plates.
Anybody else notice it was blowing excessive white smoke on cold start video?
Could be but he didn’t let it run long enough to find out. I woul request to see a video of it running warmed up.looks like normal condensation to me. you can even see it drip out of the left pipe.
Valve seals maybe....Could be but he didn’t let it run long enough to find out. I woul request to see a video of it running warmed up.
I know the upper trim on a 440 is held on with studs (that can be ground down flush), and I think rocker trim is the same, no holes.being that an R/T comes standard with rocker trim, there are a bunch of 5/16 holes that have been filled on the fenders, rockers, and quarters......... that's a bit of a turn off for me
why not source the trim instead of fill the holes? it's out there.......... I think I know the answer, a non Mopar guy selling a perfumed car
You are thinking wrong... There are holes...I know the upper trim on a 440 is held on with studs (that can be ground down flush), and I think rocker trim is the same, no holes.
I seeYou are thinking wrong... There are holes...
