Bought a 70
I thought I seen that car before. Did you buy it from a guy name Dave?
I don't remember his name now, he also had a nice red 69 Charger and a 72-74 Cuda as well.
The cam is in and degreed. since the cam has 4 degrees of advance built in I installed the chain 4 degrees retarted and and it came right in at 108. So I will reinstall the cam gears to take advantage of the 4 degrees built in.
Moving right along Jeff. Did you go through the heads before you installed them?
So I assume you will be painting the block black and the oil pan, heads and intake yellow?
I wouldn't want it to clash in that orange engine compartment.
Got the rockers set up and push rods ordered. Had to talk to Mike at 440 Source to set up the push rod length right. He's always happy to help!
