Brake Booster Removal
Moparfiend
1:01 AM
HOT
I am removing my brake booster. What is the best way to disconnect the lever pushrod assembly. In the FSM says to remove the lower pivot bolt not sure which they are referring too.
Do I need to also remove the pushrod nut and bolt?
It’s very tight in there with the bracket surrounding the bolts.
Thanks for your help on this!
Ron
I’ve removed the bottom bolt but the upper that holds the push right in doesn’t clear the bracket. It doesn’t need much to come through, but it’s still just doesn’t clear.
Need to pull this bolt out. At the pedal end of the pushrod
Push the upper bolt back in, the whole abortion slides out with the booster.
