Aron Gleason
So ever since I replaced the cam and lifters and timing chain last year I've been battling a oil leak at the bottom of the timing chain cover on the passenger side. I used the repair gasket piece that comes with the felpro gasket set, with red high temp sealer on both sides paying attention to the corners. I let it sit for a week before starting it. It doesn’t leak just idling, but after driving it leaks at the same spot. I read after replacing the cam that can cause more crankcase pressure and oil will find its way out. For more than 30 years ive either had breathers on both valve covers with the holes, then breathers with hoses running out to the atmosphere. Is running breathers with a hose on both valve covers good enough? Ive seen many people run that way with no issues.
