A simple voltmeter and test light will tell you a lot of things when it doesn’t start
If it starts one day and runs fine and doesn’t start the next day , could bee as simple as a loose wire connector , wiring issue
When it is running , measure volts at both sides of ballast
Volts at positive side of coil
Points / Condenser like mentioned - Points Burnt or , how is the gap
When you know it starts and runs , engine off key off , pull the high tension coil ignition wire out of middle of distributor cap , ground it with a gap , either have someone turn the engine over or use a remote start , is the spark blue and crisp , or yellow and weak
Same with distributor cap off , checking spark at points , turning the engine over , how does the spark look
Bulkhead connector - Not familiar with the wiring diagram on a 1966
If it won’t start when the coil is hot versus starting with a cold coil
Distributor cap and rotor
So many possibilities
