- 8:42 PM
- Mar 11, 2025
- Parksville,British Columbia,Canada
One of the 2 support studs for my steering column has been broken off. Is there a way of replacing it?
DOes it unscrew? Looks like they are pressed in from the topJust get the broken part out. You can find a replacement stud or use threaded rod.
It unscrews.DOes it unscrew? Looks like they are pressed in from the top
Oh,greatI can probably just use bolts instead of nuts and studsIt unscrews.
Not pressed. You can see in this pic two are in and the third is unscrewed.DOes it unscrew? Looks like they are pressed in from the top
Are you sure. I thought 66-70 mounted the same. Here is a link for 67 steering column brackets. https://www.ebay.com/itm/3574522870..._ms=&msclkid=6639d7927a0616e6c4c2be2f8740265cI only have 2 studs,
Wow,that sure helps. I'm thinking i will weld a nut on the remainder of the broken stud and the heat and the extra leverage should allow it to come out. Thanx so much for the picsThe stud can be replaced. Lower the column partially while supporting it with the nut on the other stud. Then grasp and unscrew and the broken stud. Unless previously over-tightened, bound up or corroded, they are often not real tight. Vice Grip pliers or Vampliers work well for grasping the broken stud if it is sticking out enough. If there is not enough material to grasp from the bottom, there might be enough extending through the top of the frame bracket to grasp and turn it downward. If unable to grasp enough to remove it, the column must be lowered to allow other methods such as drilling out the stud.
The stud, washers, nuts, spacers, and grounding strap is shown in the following image. The strap is used on later models. A ground wire is used in earlier models including 1967.
The stud is double ended with a thread stop portion toward the end that threads into the frame nut. The threads are 1/4"-20. The following image shows a stud:
Yes,there are 2 studs that go through the slotted holes and third uses a bolt that screws into the column . Loks like I can weld a nut on the broken stud and unscrew it. I'll try using bolts instead of studs if I canAre you sure. I thought 66-70 mounted the same. Here is a link for 67 steering column brackets. https://www.ebay.com/itm/357452287083?_ul=US&mkevt=1&mkcid=1&mkrid=711-53200-19255-0&campid=5339114220&toolid=10001&customid=eb:b:vms:eb:357452287083;6639d7927a0616e6c4c2be2f8740265c&loc_physical_ms=105776&loc_interest_ms=&msclkid=6639d7927a0616e6c4c2be2f8740265c
For all of you that replied to my help post,I want to thank you. I was barely able to get the tips of my 6" vise grips on the stud and after spraying with liquid wrench and working it back and forth, I was able to remove it and replaced with a bolt. My column is now secure. Knowing that it screwed out helped a lotYes,there are 2 studs that go through the slotted holes and third uses a bolt that screws into the column . Loks like I can weld a nut on the broken stud and unscrew it. I'll try using bolts instead of studs if I can
