SpartanGarage
- 5:11 PM
- Nov 6, 2020
- East Syracuse New York
Hemmings picture!
Post an ad in the marketplace forums. There is a section for "Wanted to Buy". I'm sure someone will have one. We have some great vendors here like @QuickBpBpJust can’t get enough of this car!
2nd pic: does anybody have a hood release pivot bolt?
If you are referring to tubular UCAs, yes. Makes a big difference on castor. Also a Borgeson steering box.
The Borgeson steering box has absolutely zero effect on caster, camber or toe.If you are referring to tubular UCAs, yes. Makes a big difference on castor. Also a Borgeson steering box.
No, I'd get a new alignment guy. Those numbers are crap. I got 4 degrees of positive caster with stock parts. That idiot did a terrible job.
You can align the car yourself. See this thread:
Alignment at home and aftermarket UCAS too.
Negative caster is never desirable. Never.
The car will wander and pull side to side. I'd count on it being unsafe on the road when aligned to those specs.
Again, I'm not intentionally insulting you but I would never post those alignment numbers as work that I did. Other members post alignment sheets like that while asking why their car drives worse than before the alignment. THIS chart is a good starting point. It was written by Rick Ehrenberg, a man that knows how to make a classic Mopar steer and handle well.We didn't settle. we are researching. just putting a lot of stuff together...
What a great car it has become
Someone will get a great ride.
What color is it? Is it a factory color?
