Cruise control 4 carb
old guys rule
12:20 PM
Jacksonville, FL
Anyone out there installed an after market cruise control system on their carbureted classic ride?
Yes, I did many years ago and it worked very well. Speed was determined by adding a magnet to the drive shaft and a sensor to count revolutions. Not sure where I got it though.
Here is one that should work: Rostra C Ctrl Universal Electronic Module for use w/ Vehicles Equipped w/ A/T or M/T - Walmart.com
Better/safer than an after market I would think. What does the system cost?
You have to piece together the parts. I can talk you through it if you want to send me a private message. Some parts are hard to find if you are particular about being “numbers matching”
I installed a Mopar OEM factory cruise control system and it works way better than I expected. It wasn’t too tough
Aren't the units with good diaphragms hard to find, or are ther other units that don't use that style of transducers? (sorry, that's a GM term)
Not numbers matching, just thought it might be safer to trust the original engineers. Appreciate the offer though. Apparently they can't be bought new, what was I thinking. I think I'll look into after market units. I'm just so used to cruise on the highway, I tend to cramp up. Too many birthdays.
Well, if you can find one and/or someone to rebuild one (if needed?) let me know
I've installed the same system and post two on my stroker roadrunner and on my Chevy pickup it's a universal install very simple very easy take your time make good connections you just have to put in a electric generator for your speedometer which is 80 pulses or 800 pulses per mile I don't know it's any instructions I don't remember but it comes in the kit it's all in one
Thanks, I 'll look one up
