Hi Guys! New member from Finland introducing myself.. And No we don't have polar bears, penguins and **** running around here :icon_lol:
I have 1972 Charger wich is originally from Mexico. Does not have any vin number or whatsoever but a mexican Tax number. But i guess that's the way it should be ? The cars was in Nuevo Leon an has "vin" like T2-15477 Are there any mexican members that could maybe tell me is there any way to tracew this car back to tell what is should be..
Original paper from 12.may.1972 tells me:
First owner Automoviles Y Camiones S.A. Mexico D.F. 28.6.1972 (Dealership?)
Second owner Grupo Cydsa S.A. Monterrey N.L 22.1.1973
Third owner Rene Torres Aranda MTY N.L. 1975
Fourth owner Carlos Saucedo MTY N.L. 1980
It looked like this when it came to me:
And since it wasn't in the best shape i started recently working on it. Needs some body work, all new bushes and chassis parts, new built engine wich is now under work also.
I bought 1967 4bbl 440 from Florida with 727.
Well but now the car looks like **** :icon_lol:
Color will be changed and maybe.. just maybe i'll change the shape on the rear quarter windows since i hate these small version. Looks better it they are bigger like on 1974 and when you open windows on your rear quarter and doors. Looking to buy a chin lip and go wing also. 8 3/4 rear axle is also on the list since this has the smaller one. Lets see what it will be.. I have no tight schedule since i have a family and some other things to do also.. But i'll try to do as much as quick as i can.
Engine recipe at least for now is:
1967 4bbl 440 from plymouth.
- Block machined for 030 pistons and 1/2 oil pickup.
- KB performance pistons 237-030 Hypereutectic
- Stock LY rods blasted with modified up to have floating wrist pin
- Stock crank balanced and weighted for new pistons
- 440 source 7qt, oilpan
- vintage tray
- 440 fluid damper
- Sealed power 224-4174V high power oil pump
- Compcams 21-227-4 Camshaft, 1-Bolt, Hydraulic Flat Tappet, Advertised Duration 275/287, Lift .525/.525
- 440 Source 2001055, Mopar, Big Block, Stealth, valves 2,14/1,81", 84cc heads
- Comp cams valve springs 911-16
- Comp cams hydraulic lifters 822-16
- ARP bolts
- Edelbrock victor etc..
Also bought myself E.Z 21 circuit wiring kit from ebay. Looks fantastic. Since all the original wirings were messed up.
Any comments are welcome.
I'm having a hard time taking the torsion bars off.. Tried to pry the lower control arm agains subframe.. nothing.. trying to hit the torsion bar removal tool.. nothing..
- vintage tray
- 440 fluid damper
- ARP bolts
