Thanks guys...The brake pedal does not light the dome light unless car is running. Everything else works perfectly, brake lights, turn signals, map light, running lights, all except door switches. I haven't had a chance to track it down until this weekend. BTW, my car is almost like new, stored for 35 years, has 39K miles on her. Nothing has been disconnected except the trunk light wire. It kept blowing a fuse, so obviously something is wrong there. Also, I just replaced the brake master cylinder, so my son had to pump the brakes a lot while I bled the lines...I will replace stoplight switch tomorrow, see if that fixes it. Thanks again for your input! Later TB
