Where to buy Motor Mounts
Jetblast
8:11 AM
Cincinnati Area
I am putting a 1969 440 block in a 65 Coronet and need to buy motor mounts. I would appreciate any advice on who would be a good vendor and if you know of a part number, that would be great . The K member is a V8.
Thanks in advance for any help.
I think Mancini carries some too, may be Schumachers...
Check this out:
On some parts store mounts, the stud that connects the insulator/pad to the metal bracket is TOO LONG and contacts the engine block! Be sure to check fitment before tightening everything down. This could result in a crack in the block which is obviously NOT a good thing.
I've been using the mounts Mancini sells that has the bolt through the drivers side along with a torque strap and have been happy with that setup. Ran the Schumachers in the past until I had a failure with them.
Thanks for all the info. I ended up buying some from Schumacher, Mancini sells Schumachers for a few dollars more
