Hi guys, I'm running an 850/mech secondary carb on my 440..and it works great but I always seem to be rich at idle(750 rpm). (DISCLAIMER=doing it old school for now, no A/F meter)
Anyways I can clean the idle up by going in a little on the 4-corner adjustment. However, this causes a loss of power and response from off-idle up to maybe 2500rpm or so. 6.5 PV in it now pulling 15-16 in/hg in gear at idle, PV not opening too soon. Adjust it fat again and it picks back up. Transfer slots and butterflies are ok, float levels are properly adjusted to just about halfway up the sight glass (it's a Demon not a Holley where they need to be just dribbling out the bottom), no hesitations/bogs/burps or any of that as I've spent time dialing that stuff in. So, my thought is either the low-speed air bleeds need to be opened up a tad? Or the IFRs closed a little? These are not adjustable on my model so I don't want to drill something out and have it be the wrong direction. I've turned in the 4-corners and raised the floats to try to compensate, that wasn't the answer. I get that it's more of a race-calibrated carb and I can live with it if need be, but the gas smell can be strong and it dirties up the plugs fast...I guess to sum it up what are your ideas on how to clean up the idle while maintaining the mix for power on the low end? Thanks!
