BeatersRus
- 6:02 PM
- May 31, 2015
- paying it forwards
selling my 66 coronet 4 door.
its got the original 318 2 bbl poly motor and auto trans.
runs and drives and stops but needs at least one wheel cylinder and the master cylinder should be changed to newer modern one because the brake master will loose fluid after awhile.
car has 37,777 miles on it.
car needs cleaning and paint,has been sitting for around 20 years.
interior color is red,with a yellowish white exterior.
all the lights,signals,and horn works.
car starts right up,has new carb/but i am having issues with these carbs/from china/narf.
acts like vacuum leak but no leaks found,will need tuning.
( other carb is doing the same thing on my ramcharger )
my plan was to paint it black to contrast the red interior.
asking 2200,and she can be fired up and driven onto your trailer.
sold as is with a bill of sale,there is a Copy of the reggie,and some other prior owners info.
i have the original wheels but the tires were completely dead.
underside of car is very good.
exhaust is factory and quiet,all there.
Glass is so clear its amazing...you can see for miles..
also the pedals,gas,brake,and ebrake, are all pristine,and still look new.
bad things.
trunk pics show rust which looks bad but i was hitting that with the rubber mallet,
its actually a solid floor...there is no rot there.
drivers side front fender has slight bow from prior owner,
then they bondoed over it,
which they should have just straightened the fender to start with....
pass front door??!! only one !! needs some bondo down at the corners.
headliner is hanging down,needs help.
seats have covers on them which are comfortable,but
underneath those covers is old and cracked.
trades,if its an Amc car i might be interested otherwise cash is king.
thanks for looking and lmk if any questions.
okay,pics are too big to upload...new camera..
old man that cant figure out howto...
funny that...because the photobucket pics are the same size?
ill upload to photobucket then...bbs.
$1500
bad things.
$1500
