Ok..for starters, yup I've read the sticky and just about every other thread on just about every other site. I'm going to replace the seal myself. Engine is out but I don't want to completely remove the crankshaft. #5 cap is off for access. The builder offered to redo it but I said I just assume do it to save the hassle of transporting it, waiting for the shop etc..knowing full well any future failure is on me...(he, in return, gave me two new superformance pan gaskets, new viton seal, a case of Gibbs break-in oil and a couple of good filters..I was good with that.) So, just to run this by those more 'in the know', I'll put a very light smear of rtv on the block and retainer seal surfaces, (not on the crank/seal surface obviously). On the Mancini retainer with the two small side seal slots, I plan to just use rtv...let the seal locate the retainer after getting things lined up. The block-half seal looks to have good contact on both sides of the crankshaft but I think it's still a good idea to offset the parting lines a bit as described by 340challenger and others? And a very small dab of that red permatex stuff on the seal ends, yeah? Your advice is appreciated!
