Thanks mate much appreciatedThat's how they are.
Do the brakes while it's off because otherwise they are a SOB to get off.
You will need a special puller for the other side.
At no time ever will you smack the end of the puller with the sledge hammer...(ma Mopar makes strict notes on this to prevent damage)
The unfortunate truth is that sometimes, even with the best puller, the drum won't come loose without a good whack on the end of the puller while under tension.
did it break or maybe last person working it left it off as he was as frustrated as you trying to remove the hub without success....if that is the case...thank your lucky stars he at least put the nut back on.....[/QUOTE
There was a bit of pin left in the hubcap, but it could have been a crap pin I guess, just glad I was able to pull over in time
Yes, there should be a washer behind the nut. The axle end does look a little distorted but as long as the nut starts on there you should be fine. You'll see in my video I'll leave the nut on when useing the puller. Just leave at least a 1/4" for the drum to move. Protects the threads leaving the nut on there.
