WTB Subframe Connectors
Dominic
4:15 PM
San Diego
Looking for some subframe connectors, specifically for a 1968 Roadrunner !
Thanks
Are you currently restoring the car or is it done and you’re looking to add some rigidity? US Cartool ones are nice but in my opinion are more geared for ‘undergoing resto’ time frame as they are intended to welded in the full length. If the car is done already maybe consider some mopar performance ones. Mopar P4286869 is the number for your car. They can be bolted in and then welded after if you like. Mancini sell the MP ones for $199, they also have their own version for $179. I also recommend phoning a few chrysler dealers and asking them how much as they may surprise you and be less than everyone else.
Good luck
If you can weld they are pretty easy to fabricate. 2x2x1/8"/3/16" square tube. I like to cut into the rear pans just enough to tie some of the floor into the system (6-8").
Mike
