Demonic
Demo Derby engine = it ran hot at least once, or more. I'd be very wary on the heads, and check the block for heat damage carefully! Get aluminum heads, and run at 10.5:1. - you'll need pistons.
Welcome from NY.
Just remember: "Dreams are expensive"
Keep us posted.
Welcome from the show me state, Missouri!!! I like the way you think.
A 440 is a great place to start. You will be very happy with the finished product.
Would Aluminum heads (and intake manifolds) deflect, warp and generate leaks as the engine is duty cycled?
The short answer is no, as long as they're properly installed and coolant system maintained. Not the cheapest way to go, but you wanted compression.
Welcome from north of WinnipegHello Everyone,
This is my first first forum post ever...so here it goes! I have been reading and researching For B Bodies only for a while now and decided to become a member because of all the very informative, helpful, and good stuff that is helping me with my new-ish hobby: building my dream car - a B Body Charger!
I have (0) experience building cars, engines, transmissions, rear-ends, suspension, electrical and fabrication. However, I'm a handy fella with a technical background, an adequate amount of skillset, a fair amount of patience and a quick study. The biggest engine I have ever re-built was a single-cylinder Kohler 241 single cylinder garden tractor engine. So I have a lot to learn!
The Goal: To leverage my research, skillset and resources and acquire a my dream Car (1968-1970 Charger) with my dream engine (RB-440: have this in my shop!! Good story there) and transmission (4-Speed: A833) and build a street-able cruiser that is reliable, sounds great and...if needed...can really get-up-and-go!
I will need all the advice I can get because of my lack of experience. Nonetheless, I have wanted a Charger since I saw my first Dukes of Hazzard episode, my best friends in High School and I all pooled our money together an bought a 1973 Charger in the 1990s (good story on that one), and have worked to acquire resources to support this endeavor.
Thank you all in advance for any guidance, direction and advice!
Welcome to the site.
Check out THIS thread of mine:
https://www.forbbodiesonly.com/moparforum/threads/lookie-what-5000-buys-you.178346/
It shows the progress of what an "affordable" Charger looks like and the problems that you'll likely encounter with one.
Spend more, you'll get more.
I bought it just for fun. I already have a finished one but figured I could build this one with parts saved from the first car.
