1969 GTX, 440 with about 8k miles since PO rebuilt. Crane cams 280H series (230/230 duration with .481 lift), Brawler carb, Carter 6903 fuel pump with OEM vapor return canister.
With the return line in service, the crappy edlebrock pressure gauge wildly fluxuates between 0 and 10 PSIG. With the return line squeezed off, the pressure fluxuates between 2.5 and 3.5psig.
Rebuild/replace fuel pump and or vapor return canister?
Car runs pretty good, but I cant get it tuned to the point where it doesnt stink and eye burn.
Could the pressure strangeness be related to or be the cause the eye burns? (wont tune because of inconsistent fuel pressure)?
Dale
Dale
