Odd Rod
New Member
Has anyone experienced an outer bearing failure as shown in the attached picture? This 65 Sat is new to me and is a drag car being converted to street use. I was driving it home from the muffler shop and hit bump in the highway doing roughly 50 mph. I heard an awful shriek, it quickly quieted and the drive continued. The next time I took the car out for a short ride the passenger side bearing failed, I removed the axles, had new bearings installed and just wanted to see if anyone experienced this before I reinstall the new axles/bearings into the car. Of not, the shocks were worn out on the car on all four corners. I went with Gabriel gas shocks up front and Air shocks on the rear. I am hoping that will soften the ride and eliminate any chance of bottoming out?
Photo 1 - Driver Side Cracked Race
Photo 2 - Driver Side Left and Passenger Side Right
Photo 3 - Driver Side Axle Tube
Photo 4 - Car on Lift
Photo 5 - Failed Bearings, Race and Seal Spring Parts from Passenger Side
Photo 6 - Passenger Side Installed in Failed Condition
Photo 7 - Driver Side Installed in Failed Condition
