1964 Pontiac GTO 389 cu Tripower,4 speed,3.90 posi trc Date Code Correct
  • Added by Gonzo_V
  • Create date Create date
  • Last update Updated
About this Mopar:
This vehicle is a Date code correct or aka numbers matching 'which is a misnomer because Pontiac " nor any other manufacture" did Matching Numbers in 64. Date code correct is more accurate because you had to make sure the Block/heads/manifolds we stamped or were cast before actual assembly date of the vehicle.
Item information
Category
FBBO Member Photo Garage
Added by
Gonzo_V
Views
2,103
Comments
1
Last update
More from Gonzo_V
